2G Help with no start
dsm_delion
May 6, 2025
sioux city, Iowa
So my Eclipse was running perfectly fine one day and then I put it away. Next day I go and try and turn it on and I get power and fuel but it just cranks and won’t start also tried push starting it and wouldn’t work either anyone know what it could be? 1997 7 bolt 4g63 fwd
Air, fuel, ignition, timing
If one is missing or not right the engine won't run. You have to figure out what you're missing then we can help diagnose from there.
So I scanned the car and I got a code for the pcv valve but im not sure where that would be at
The chances of a PCV causing a no start are slim.
I have air I have fuel and I have spark changed the spark plugs and ignition coils that didn’t change do anything scanned the car this morning and it gave me a code for PCV the code was P0443
Thats not pcv valve. Its purge control valve solenoid.
