2G Boost leak test
jerrylarsen
147
5
Nov 23, 2014
arvada, Colorado
So I was trying to do a boost leak test, and I never got more than 2 psi. I could hear and feel it going out of the exhaust. I kept pressure up while turning the motor slowly by hand and never got anything. So bad valves? Or bad turbo? The car still builds and holds boost, just it doesn't have much. I'm steady at 7 psi.
So... What's going on with it? Any help would be so helpful guys.
Maybe egr is stuck open?
Yeah I am, I'll try that tomorrow
Yes out of the tail pipe. I turned the motor by hand slowly two entire revolutions and never got more then 2 psi
I know I know, I was turning it trying to find the proper place LOL cause I assumed I was wrong because my boost wouldn't build. Where should my cams sit? Have a picture?
I tried with where I thought it would be and was wrong apparently LOL
I figured I'd have to pull the crank shaft pulley or something to get it correctly?
I don't think there's any markings on it, but I suppose it would help if I looked haha
The crank pulley (aka harmonic balancer) has a mark (or notch) on it's outer circumference. The lower timing belt cover has a tab with 5* increment lines on it. See 1st and 8th pictures here: http://www.plymouthlaser.com/timin.htm. So turn the crank pulley to approximately 30* ATDC - the exact position is not critical, just get it in that area. [Note: You can also just barely see the tab if you sight down in front of the water pump pulley towards the crank pulley although it would be easier if the alt belt wasn't there. I'm assuming you have a 2g.]
Thanks for the replies,
I'll test it soon and let you know.
Is there an easy way to test the EGR?
I'm sorry. I previously told you that all intake valves are closed at 40*BTDC. I didn't know what I was thinking - obviously there is ALWAYS at least one intake valve open on one of the cylinders at any time. For a BLT you want to make sure BOTH intake and exhaust valves are not open at the same time in any cylinder (valve overlap). That is why crank must not be at TDC (30* ATDC recommended).
Okay, I blocked the egr off (no emissions anyways) did a blt and found ass tons of leaks, injector #1 was the worst, all around the throttle body at the boltls, a large copper colored flat head screw... What do I do for those LOL
Probably have to replace injector o-rings (aka insulators):
http://fuelinjectorclinic.com/index.php?route=product/category&path=252_257 OR
http://www.dsmtuners.com/threads/lower-injector-seals.388643/#post-152428118 OR
http://www.streettunedmotorsports.com/parts/oem_dsm_fuel_rail_spacers.htm OR
http://www.streettunedmotorsports.com/parts/oem_dsm_lower_injector_insulator_rings.htm.
New throttle body gaskets or put sealant on them.
Also check for throttle body shaft seal leaks (which are VERY common on dsms) while opening/closing throttle plate while doing BLT: http://www.machv.com/throtbodseal.html
Check if BISS o-ring leaking/missing.
Check valve cover gasket area for leaks.
Check BOV fitting for leaks.
Check all intake hose fittings for leaks.
I believe the flat copper colored screw is your BISS. It's in a hole in the throttle body. Before removing it slowly screw it in all the way counting half turns and write it down. Then unscrew it all the way. It will be stuck in the depression. Cover it with a rag and do a quick BLT. This will blow the BISS screw into the rag. The screw is usually reusable. Just get rid of the old oring and get a new one from your favorite hardware store. I used a little hi temp plumbers lubricant on the new oring. Now screw it back in all the way. Then back it off the same number of half turns that you previously wrote down. Next BLT I'll set the crank correctly first. Thanks luv2rallye.
Well I fixed the injector leaking, I can hear something leaking down lower though but it sounds like the transmission though haha. I couldn't look more because it started hailing, I got up to 20 psi in the intake, right as my boost leak tester blew off LOL, changed it to t bolt clamps and will try tomorrow
  • For sale 1g Assortment of New, Used, and Unobtanium Parts
    All good stuff. Will sell individually or lot sale.
    • 8716valver
  • For sale 2g 95-98 Talon air bag.
    2g Talon airbag. Really good condition. Can ship ups ground. Message 702-741-6987
  • For sale Injen Intake System
    Good condition used Injen Intake System for Turbo DSMs
    • kyler021
  • For sale 1g 1G Driver & Passenger Door Jam Seals
    1G Driver & Passenger Door Jam Seals $50 + shipping & paypal fees* these are the door jam...
