boost leak test
KeelesKustome
882
17
Dec 29, 2007
Waverly, Tennessee
i am doing my boost leak test and air is comming out of the lid of my valve cover..... verry slowly untill i remove the cap.... what does this mean.
Try pinching off your PCV valve and re test it at the TB to see if it still comes out of the oil cap or breather vent. Make sure when you are testing you use a spray bottle of soapy water and look for bubbles.
Most likly your PCV valve is leaking. This is a cheap and easy fix. Just install this: 3/8" Kynar® Standard Check Valves | U.S. Plastic Corp. inline between your intake manifold and PCV valve. You can try pinching the line like liquidx said but I would get the check valve either way. Also as mentioned, start you BLT's at the throttle body inlet and once you get everything fixed, and it is holding to your liking, then work your way back.
Hope this helps!
i have been using the water bottle, i have every leak fixed untill this.
i was considering the pcv valve as it looks worn, and i remember having some similar issue with it making my dipstick blowe out while driving, 3 years ago.
does my ssq bov need a purge valve allowing air to only go 1 direction?
just pinched it and that was it thanx
Glad you got it figured out. You can either get a new OEM valve or get the check valve mentioned above.
You'll need to recirculate your BOV unless you have a Gm MAF in blow through or running speed density.
yeah i plan on recirculating it, but it came with a valve so that air can only go 1 way on it that goes to the intake mani.... do i need that little valve cluttering my bay?
  • For sale 2g 95-98 Talon air bag.
    2g Talon airbag. Really good condition. Can ship ups ground. Message 702-741-6987
  • For sale Injen Intake System
    Good condition used Injen Intake System for Turbo DSMs
    • kyler021
  • For sale 1g 1G Driver & Passenger Door Jam Seals
    1G Driver & Passenger Door Jam Seals $50 + shipping & paypal fees* these are the door jam...
  • For sale 2g 1997 Mitsubishi Motors Eclipse Service Manuals
    1997 Mitsubishi Motors Service Manuals $50 for the pair + shipping & paypal fees* I priced...
