boost leak test question
that depends on what you have in your setup but as long as everything is sealed up and connected right it should run 15 psi till you run out of rpms. if you are talking about boosting to 15 psi then shutting down it will instantly drop. could you be more detailed with your question??
When pressure testing if your inlet fitting seals then the longer it holds pressure the better.
If there are no leaks at all it should hold pressure forever but that's an ideal, not reality that anybody reaches. If it will hold the pressure for a couple minutes you clearly got all the big leaks.
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
