Boost leak test question
dsmcoder
382
Oct 12, 2010
Havre, Montana
I have access to a smoke machine that can check for vacuum leaks, will this machine give the same results as a boost leak test? If not can you show me a good guide to make one.
Thanks
Thanks for the guide but I would like to make one with a gauge on it so I don't have to worry about putting too much pressure in the system.
You can modify the $5 gauge so that you can install a gauge with it, or... you can simply turn the PSI down on your compressor that you'll be using when you do a BLT.
Above post beat me to the Post button.
I couldn't believe how many leaks I had on my car. I had to seriously crank my couplers to get them to seal and the most interesting leak was the seal on my turbo housing. It wouldn't even hold 4 PSI.
I couldn't find all the parts I need at my local stores so I might have to buy one online.
I purchased one offline with a gauge on it and it was the best thing I've bought for my car so far.
If you want to hear something interesting, i used a plastic foot from a couch and tapped it with an air compression fitting and threw a coupler on the thing and works like anything you can buy LOL.
That's believable. I think I heard someone use the end of a gatorade bottle to boost leak.
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
