boost leak test question
dsmeclipse16psi
44
Jul 17, 2007
roanoke, Virginia
:confused: ok i know how to make a boost leak tester but i do not understand how to do a boost leak test i dont think i have one but i just think its good to check
pull off your air intake, put on your tester and pressurize it up. test it with what amount of boost you run , dont go to high on it.
im not understanding what you mean i need more details LOL how do i find the leak really i just dont know what to do at all
you would hear it hissing. you can also spray soapy water on all your i/c pipes and connections. you take off your air intake from your turbo,then put your tester onto your turbo were the intake came off. then with a air pump or compressure pressurize it to the\amount of boost you run. then check for leaks on your lines etc..
