Boost leak test question
SlickPyro
226
7
Jun 5, 2008
South Euclid, Ohio
I tried to do a boost leak test and there is absolutely no movement on my boost gauge. I have one of those nxs boost controllers, should I try taking that out and putting a straight thru fitting on there? I had a leak at my j pipe but i put a new gasket in there and still nothing. I think the j pipe might be my problem because I blew out the new gasket to. And I am only running 10-15 lbs of boost. Any help would be appreciated. Thanks.
Yea i prob shoulda mentioned that I have an autometer boost gauge. it is in a slew of vacuum lines right by the fuel pressure regulator. I'm not sure exactly what line it is tapped into. I can look tomorrow at school. I'm getting ready to pull the motor and put it in another laser shell.
^ That is only necessary if you have an electric boost gauge. If it's a manual gauge, it should work no matter what.
The line that goes to your MBC that provides the boost source should be removed and capped off. This is because your boost controller should have a small bleeder hole in it which will be a boost leak.
Did you follow the steps in this post?
http://www.dsmtuners.com/forums/new...ar-boosting-runs-like-crap.html#post151301533
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
