Boost leak test question
99 gst spyder
522
Jul 12, 2007
st. paul, Minnesota
I did a BLT today and I can hear my turbo spool very loud and not sure but at the same time, seems like a loud hissing coming from the the o2 housing area. Either the o2 housing, dp, ex. Manifold gasket, wastegate or something around there. My tru boost gauge will slowly go up to 12 psi max then slowly drops down to zero. I don't know if the 12 psi max has anything to do with my 14psi waste gate spring.
While driving, I don't have any problems with boosting. I would hit my 14psi waste gate spring like nothing and would hold there until I let go. Still feels pretty strong and boost fine. Just sitting a little low on vacuum around 10 at idle.
Over all I don't seem to find any leak elsewhere.
Anything would help.
Well I just put the engine to TDC and I don't hear the very loud turbo spool or that very loud hissing noise anymore. All I can hear is the air entering the turbo but even with spraying water, I can't find much air bubbling much. My only problem now is that If its at tdc, I can't seem to get any reading on my tru boost gauge now. But if I turn the motor a little to not have it at tdc, then I get readings on the gauge. Weird.
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
