Spyder Big brake kit
Yoshida445
52
5
Jan 9, 2023
Conyers, Georgia
I want to do a big brake kit upgrade to my 2g and wanted to go with R1 concept but I don’t know the dimensions of the front and the rear. If there are any other better big brake kit that would fit my 2g let me know.
Looks like they just sell rotors and pads.it isn't an upgrade. What are yiu wanting to do?
Filling out a profile for your car is a good idea.
Assuming this is a 98 Spyder GST either the 2 piston calipers from the AWD cars or the Outlander upgrade might meet your needs without spending too much. Unless your need is primarily for looks.
Big brake kits come in various options from price to size and calipers. Could be a kit from another chassis or a custom part / aftermarket, so a budget is ideally needed to be known. Kits can be pieced together for about 400+ other kits will be more so depends on alot of factors but 99% its budget.
Okay thanks
I'm not sure maybe putting like Brembos on it but I'm not sure what Brembos to use and if they would fit the OEM banjo or if I would have to do some modifying
Okay, and yes its a Spyder GST. The 2 piston calipers from the GSX would bolt right up to the OEM banjo from the GST or would there need to be some modifying done?
Would there be any good brand for front and rear brake rotors and calipers that clear 17” wheels?
