Banjo bolts turbo
Sjd6795
614
121
May 14, 2014
Wilsonville, Oregon
Does anyone know if advanced auto, napa, o riley, autozone etc.. Carry banjo bolts and crush washers for our cars? The one on my 14b is beat up and want to replace it.
I dont know that they would have one with the right thread for a turbo, they carry some though, crush washers they do have for sure.
Try to look for with the size or the part numbers below.
Oil feed line banjo bolts
Head side : M10 x 1.25 x 20mm (Part number : MF650102)
Turbo side : M12 x 1.25 x 23mm (Part number : MS650013)
Coolant line banjo bolts
Both side : M14 x 1.5 x 27mm (Part number : MF650114)
Washer (Required 2 washers per bolt)
M10 (Part Number : MF660063)
M12 (Part Number : MF660064)
M14 (Part Number : MF660065)
Maybe it's just *my* Fastenal, but they've never had anything I needed, including banjo bolts. They had no idea what they were. I wouldn't hold my breath on them having what you're after...
My Oreillys had banjo bolts that I used when I converted my 92 over to dual piston 2g calipers. Just FYI.
No. Those are different. Brake caliper banjo is M10.
Ah damn ok mine seals good and everything it's just the head is a little scarred up. Removing it and re torquing has me worried. It's only the front one so I can easily access it at a later time though without removing anything.
