1G Awd MT all torque spec for rear main seal
AWD-Tony
6,787
3,749
Sep 11, 2017
Cincinnati, Ohio
I put this together so you’ll only need this page for most torque specs to replace rear main seal, flywheel, clutch or manual transmission.
I left off simple items like slave cylinder, downpipe and other small brackets/miscellaneous items.
Rear main seal 7-9 ftlbs
Oil pan bolts 5 ftlbs
Flywheel bolts 35, 75 then 100ftlbs - red thread lock
Pressure Plate bolts 18-22ftlbs - blue thread lock
Manual transmission - blue thread lock
Rear bolt 12mm 22-25 ftlbs
3x 14mm bolts 31-40 ftlbs
Drain plug 24mm 22-25 ftlbs
Fill plug 17mm 22-25 ftlbs
Starter bolts 20-25 ftlbs
Mount
Bracket to transmission 43-58 ftlbs
Through bolt 43-58 ftlbs
To frame 29-36 ftlbs
Transfer case 40-43 ftlbs
Drain/fill 22-25 ftlbs
Gusset 51-58 ftlbs
Right member
3x 17mm bolts up front 58-72 ftlbs
Center long 14mm 51-58 ftlbs
Rear short 14mm 51-58 ftlbs
Driver side axle carrier to block 26-33 ftlbs
Struts to knuckle 80-101 ftlbs
Tie rod 17-25 ftlbs
Axle nut 144-188 ftlbs
I used this and other threads. Thanks to 19eclipse90
https://www.dsmtuners.com/threads/what-size-is-that-bolt-nut-stud-fastener-1g-version.437697/
Thanks for putting this together, I am doing this all now and it will be super handy.
In case anyone else is determined to torque everything to spec, here are the additional ones you mentioned:
Clutch release ("slave") cylinder: 11-15 ft/lbs
Clutch release cylinder banjo: 14-18 ft/lbs
Downpipe to O2 nut: 29-43 ft/lbs
Downpipe "hanger" nut: 22-29 ft/lbs (usually only on a stock downpipe)
In case you remove the brake calipers from the hub:
Brake caliper bolt: 58-72 ft/lbs
All specs from the FSM.
Good call. I forgot the caliper and bracket
Caliper bracket 65 ftlbs
Once you bolt the slave, make sure the fork rests towards the drivers side of the window. Mine was dead center and now I have to shim it more.
222 is a hella lot.........ROFL :p
No, you should be able to. Can I help out Tony? Need me to change something?
I can't for some reason and I notice on some posts you can't edit.
Can you please change below on the first post?
Thanks, Marty!!
Take a look and make sure it reads how you want it Tony.
I have found that the "Edit" time, sometimes runs out if you don't notice a error pretty quickly, but I can always fix it for any member if needed. :thumb:
Perfect! Thanks, Marty!
  • For sale 1g 1G AWD Engine Side Splash Shield
    1G AWD Engine Side Splash Shields $55 a piece + shipping & paypal fees* I don’t have any...
  • For sale 2g 2G OEM Cargo Net
    2G OEM Cargo Net $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 2g 2G Auto Shifter Cable ( GSX/GST )
    2G Auto Shifter Cable $45 + shipping & paypal fees* GSX/GSTYou must be registered to see...
  • For sale 2g 2G Auto Shifter Base
    2G Auto Shifter Base $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 1g Mishimoto radiator
    Mishimoto X-Line Aluminum Radiator | 1990-1994 1G DSM (MMRAD-ECL-90X)
    • william
