AWD-Tony
- 6,787
- 3,748
- Sep 11, 2017
Cincinnati,
Ohio
I had to jump around looking for these specs, so here it is all on one page.
Top 72-87 ft lbs (100-120 Nm)
Side 72-87 ft lbs (100-120 Nm)
Rear 58-72 ft lbs (80-100Nm)
Inner lower control arm 65-80 ft lbs (90-110 Nm)
Drain Plug 43-51 ft lbs (60-70 Nm)
Fill Plug 29-43 ft lbs (40-60 Nm)
Cover 22-30 ft lbs
Boomerang 80-94 ft lbs (note the orientation of bottom cup)
Rear subframe nuts 80-94 ft lbs (note the orientation of bottom cup)
Lower bushing bracket bolts 51-61 ft lbs
Axle to cup 40-47 ft lbs
Axle nut 116-159 ft lbs
Cover 22-30 ft lbs
. Only you Vegas!
