AWD-Tony
- 6,787
- 3,748
- Sep 11, 2017
Cincinnati,
Ohio
Anyone know the torque spec for the gas tank drain plug?
thanks
Tony
thanks
Tony
12-19 Ft. Lbs
Yes, it takes a washer/gasket thing. If you get one at a parts store, verify that it can tolerate exposure to gas. I tried a copper crush washer, and couldn't get mine to stop leaking, which was a bummer since it is a real pain to empty the tank repeatedly to try again. The washer was very thick, so perhaps a much thinner copper or aluminum would work, or if I had dared to reef on the plug more to tighten it. Eventually I ordered the OEM part from Japan, but I suspect NAPA, etc. have something similar.
