Rear main seal fix..?
19-MODTSI-93
May 9, 2013
Watertown, South Dakota
hey guys im looking at buing a 93 talon tsi from a guy the motor was rebuilt but his rear main seal is leaking... hes asking a good price for it but I am wondering what all is involved in replacing the seal? thankyou I would like to know step by step so if i buy it i can fix it right away and drive it as it will be my daily
Simple fix remove tranny and its there to see plus grab a manual to go ahead to deal with him, its a 25 dollar part or so.
If you need help vfaq is also available to help.
^^ Kind of!
Transmission/t-case
axles
clutch/flywheel or flex plate if you're auto
down pipe
and oil pan.
Once everything is off, then your seal will be visible. 5 10mm bolts hold the "housing" on. Just use a screw driver and remove the old seal and tap the new one in. New gasket and bolt it back in and reassemble everything. Its a pretty lengthy job for just a seal.
