420A Auto to manual, speed sensor not working
Brad Bell
202
11
Aug 15, 2014
Levant, Maine
Using the instructions http://www.2gnt.com/?d=ATMT I did an auto to manual conversion on my 1999 eclipse gs 420a. Everything works fine except the speed sensor I wired up. I wired the three wires coming from the speed sensor to the wires corresponding on the ecu plug. I don't know for sure the wires are the correct ones, so if anyone knows for sure which wires that would be great. The power is going to the sensor, reading around 8.9 volts, but there isn't anything coming out, if so only slightly. The gauge cluster doesn't budge. Someone please help!!!!!!!!
You do have the auto trans computer unplugged or if its still plugged in, the (yellow/white) wire is disconnected from it, correct?
Pull out the gauge cluster and youll see 3 plugs. On the plug on the right, you need to check voltage between the bottom/left pin and ground. With the ignition switch on, you should get battery voltage
here is a copy of the electrical manual if itll help
http://www.mediafire.com/download/6v705mm1dzx/97-99Electrical.pdf
If its still connected, you will have 2 paths for the current to travel, take a look at the diagram, on the AT it shows the (yellow/white) wire goes to an internal ground inside the ATX ecu
where as on the MT it is internally grounded at PCM PIN44 (black/green) .
The (yellow/white) wire shouldn't be connected to the ATX ecu
So if I cut the yellow white wire from the atx ECU it should possibly do the trick?
Can you just unplug the trqnsmission computer, then turn on the ignition, then check the voltage between Vss plug PIN3 (yellow/white) and ground (-).
Holy shit that did it!!!!!!!! Wow I can't believe it was that simple just to unplug the computer!!! Thankyou so much for helping me out with this you saved my ass. Thankyou
Cool. Glad you got it working.
if you havent switched to a MT PCM, doing so will get rid of the CEL and raise your rev limit 500rpms
Ok sorry for beinging this back but I have read through this thread 1000 times and It's just not getting to me can you tell me exactly where to connect the 3 cables for the speed sensor please i was just pulled over for speeding and I need it hooked up please help
  • For sale 2g 95-98 Talon air bag.
    2g Talon airbag. Really good condition. Can ship ups ground. Message 702-741-6987
  • For sale Injen Intake System
    Good condition used Injen Intake System for Turbo DSMs
    • kyler021
  • For sale 1g 1G Driver & Passenger Door Jam Seals
    1G Driver & Passenger Door Jam Seals $50 + shipping & paypal fees* these are the door jam...
  • For sale 2g 1997 Mitsubishi Motors Eclipse Service Manuals
    1997 Mitsubishi Motors Service Manuals $50 for the pair + shipping & paypal fees* I priced...
