arp main studs or oem main studs
If you are in there you might as well replace them with ARPs. OEM main studs are great too, they are proven for way more power than you are shooting for.
If you use any 'studs' youll need to line bore the block (unless the factory uses studs). If you reuse the bolts (i dont know what the 420 uses, but 4G63 uses bolts) then you dont need to do any line boring.
Why would he need to line bore the block? Studs don't change the alignment of any of the bearing surfaces...
The 420A uses main bolts from the factory.
I have always been taught / seen that line boring/honing was possibly required with ARP main studs because of the increased clamp load
Idea is, it can make the bearing journals get out of round so the machinst will torque to spec then measure the crank bearing bore with the inside micrometer to check against specs
But I'm no machinist or expert on this, so that's why I'm asking :ohdamn:
  • Wanted 6 bolt NT water pipe
    • chrisman287
