1G antilag won't build more than 10 psi?
Jt_4g63
45
Mar 4, 2010
riverview, Florida
I have a problem on my 1g it won't build more than 10 psi tried 10, 15 ,20deg
0% -5% 5% and 10% enrichment
2step set to 4000 antilag set to 3500
Less timing more boost & More timing less boost right?
Evo316g turbo ex waste with 15psi Spring
Fully built head 272 cams
255 walbro 550 fic injections
3" full exhaust
Fmic 3" core
When you lower the ignition timing that's causing the spark to ignite later, therefore causing much more heat and energy to go through the manifold and get to the turbine. The more you retard, the faster and more aggressive the antilag will be. Raising the timing will just pretty much give you a weaker 2 step. Just make sure to add fuel ass you get more aggressive, the heat generated will eat your turbo up pretty quick
Well timing really doesn't do anything to valve timing guys. It is used to set the spark to ignite AFTER top dead center and with fuel enrichment, it's gonna ignite more in the turbine. If you stand on it, long enuf, it will build boost if set close. It IS HARD on a turbo tho. That aside, I can set mine to build 30+ standing still. Can I leave on it, not yet but it is just igniting the fuel closer or into the turbo to spool it. It creates heat tho, so make your settings work for you. Don't burn your stuff down...
My bad my misinformation. My head was doing one thing and my fingers another. My post is fixed. Thanks for pointing it out!
Oh it's nothing, just a mere technicality that I usually just don't worry about. Have you played with it yet to see if you can get it to boost up?
