4gfun
Supporting VIP
- 2,009
- 56
- Dec 10, 2007
Ask Me,
Virginia
I am targeting 21 psi of boost on my 91 GVR4 before I start tuning. Today I installed FIC 650 injectors and tried to crack the boost up by turning the boost controller a few turns. The previous owner had the boost set at 16 psi and it sure pulled hard then.
To my dismay, I cannot get boost to reach higher than 20 psi at any point and it falls to 18.
This is even when I open the boost controller up all the way.
Any idea what could be going on?
Here are the performance mods if this helps:
Ported Big 16G Turbo, ETS FMIC & Piping, Counterfeit XBC MBC, Custom 2.5" tubular SS O2 housing with 40mm TiAL gate, Buschur 2.5" mandrel bent SS exhaust turbo back, CATCO cat, Socketed EPROM ECU with Ostrich and ROM emulator, Stutterbox and Check Engine shift light, Warlboro 190 lph pump, Fuel Pump Rewire, FIC 650 injectors, Innovate LC-1 Wideband O2 with guage
Such is life.
