90 GST won't build boost past 10 psi
Dave4g63
Supporting VIP
203
Nov 28, 2009
Newport, New Hampshire
today i installed an Ebay mbc a boost gauge and i also cleaned out the inter cooler.after i got everything back together took the car for a spin but it won't build past 10 psi :cry: im not 100% sure i installed the mbc right ,no instructions.. i have got pictures of how i installed it that i will include in this post. current mod list is down pipe, straight pipe . k&n filter with removed can and the mbc. so don't look at my profile for mods thats my 2g's list :p i plan on a blt but i want to make sure i have this thing hooked up right, its a bit different than the ebc on my 2g. thanks
Why did you have to get a crazy ebay MBC? They don't hook up like the normal ones. I remember seeing a thread in the past month or 2 that had a picture/diagram of the proper way to install that thing. I'll see if I can find it.
Edit: Found it!
The whole thread can be found here: Installing Ebay MBC
Hope this helps!
sweet , thanks ill try that in a few mins. and for why its a crazy ebay mbc, its not my car its my bros and he can't afford an ebc like mine so he snagged one of ebay haha.
I've never seen one like that either. I mean I'm sure it'll work fine once you have have it hooked it correctly. I diy'ed mine from home depot and boosting 17psi. Also check the couplers holding the piping to the intercooler and make sure they're tight
