- Thread starter
- #26
Ludachris
Founder & Zookeeper
- 8,880
- 4,727
- Nov 12, 2001
Newcastle,
California
If the width ends up being the same or close maybe I'll take a shot at them.
Unless you have the spindle off the car it probably wouldn't be much help. We need to compare the spindles side by side.Do I need to snap off some pictures of my evo?
)I have a hunch that the majority of racers serious enough to replace the control arms on a 1g can make their own or have a friend/sponsor help them. I guess my point is, its going to be hard to find buyers at $1300 a set. In my case for example, I'll be using the resources available at my school's machine shop to make some (that is, if I'm at that stage in my project before graduation)
Although I think that CNC'd control arms would open up a lot of possibilities for handling and even space for brake ducting, I just don't see more than a few people paying $1300-1500 for them. I don't know that I could come up with the cash for that.I think the solution to this problem is to create a production aftermarket control arm. First off, replacing the subframe is out due to the costs involved. (at least for me) Then the next step is to get a few of the committed guys together with those parameters and figure out the best course of action.
I have been tossing a couple ideas around including machining some aluminum lower control arms. I could fairly easily design these to be cheap (ish) to CNC and allow for either a standard racing ball joint (take a standard off the shelf part or a race part) or a spherical bearing receiver like pagosa was mentioning.
The advantage of doing machined arms would be two fold. 1) in the long term it would be cheaper because the largest costs are single time costs: A) designing them which I would donate and B)creating the toolpaths to machine them. (which I could do depending on who's going to be machining them) Once these two things are done, creating another arm is as simple as buying a chunk of 6061 billet and throwing it on a cnc machine. 2) Small changes like ball joint height or style of ball joint would be a fairly simple change to implement.
I also like aluminum arms due to their strength and not having to worry about quality of welds which have been a problem in the past with cro-mo tubular arms. This is compared to tubular arms where each set is a completely new project and requires just as much time as the last set.
I think (based upon other applications I've seen) that we could do these for 1300-1500$ a set. but this is assuming at least 5 people are interesting. I'm one, I think that Chris, you would be another.
What are your thoughts?
This seems a more realistic/affordable option, if we can find a balljoint with a compatible taper, or if need be, like was mentioned previously, ream the knuckle. I believe tapered reams for this sort of thing are readily available through circle track suppliers.Hey, if you want to machine something, maybe a weld-in socket (for the stock LCA) to accept a spherical bearing of spiffy ball joint?
I was in a shop today.I was checking out a 2001 talon,it looks like the lower control arm and the spindle will fit a 1st gen.The 2001 lower ball joint is the same as the evo.It looks the same ,but I might be wrong.It is something to look at.
I'm still interested in seeing if we can find out whether or not the Evo spindle would bolt right up. That would take care of the reaming issue and would allow us to use the roll center kit from Whiteline. I'll start looking for one.This seems a more realistic/affordable option, if we can find a balljoint with a compatible taper, or if need be, like was mentioned previously, ream the knuckle. I believe tapered reams for this sort of thing are readily available through circle track suppliers.
So now we need a sample ball joint. I can find a lathe if needed.
That seems even better. It would also give us (hopefully) better wheel bearings, less flex/pad knockback, seemingly infinite brake options, and on, and on.I'm still interested in seeing if we can find out whether or not the Evo spindle would bolt right up. That would take care of the reaming issue and would allow us to use the roll center kit from Whiteline. I'll start looking for one.
The spindle/ball joint height is the easiest/cheapest way to adjust roll center, if needed. The control arm is irrelevant.
No need to overthink this.
