chrisman287
5+ Year Contributor
- 1,156
- 1,105
- Jul 19, 2021
New York
I’m not sure if I’m overthinkng this but I just finished a clutch/trans job the other day. I was going to bleed the clutch line and adjust the pedal rod for maximum fluid transfer per Jack’s instructions but to bleed properly, should the pedal rod be set the opposite way? Or does it not matter? The master did run dry at one point due to a leaky line
Also, does my fork look like it’s in the right position? I used one headstud washer under the pivot ball even though it’s new. Fork I reused maybe I should’ve bought a new OEM or Competition steel one. Trans shifts smooth as butter in every gear but pops out of 1st. I have a feeling it’s not getting into gear fully while running unless the syncros are just shot. Was considering a 3000gt n/a slave if I can find the right one to see if that helps
