Necessary to bench bleed clutch master cylinder?
idt512
231
9
May 4, 2003
Hemet, California
Is it absolutely necessary to bench bleed the clutch master cylinder? I just installed a good used master cylinder and im not getting anywhere with bleeding it, the fluid in the reservoir comes back up when the pedal is pressed. Not sure if i have air in the system or a bad master cyl.
Ive bled clutches before but never watched the fluid in the reservoir as the pedal is pressed /depressed... because i never had to.
-Car is a 2g AWD
I already know theres air, ive been trying to bleed it and am not getting anywhere, the fluid in the reservoir just goes up and down as i depress and release the pedal. Even with the bleeder screw open.
I just installed a new cmc this weekend and didn't bench bleed it. I also put in a stainless steel clutch line so mine was full of air and I had no problem bleeding it at all.
