? About fuel system diagnostic check
juntjoo
780
Sep 12, 2011
fort myers, Florida
So following Haynes instructions i'm checking the fuel system and the first thing it says is to listen for a whirring noise at the gas cap when you turn the ignition to the 1st position but i'm hearing nothing. So what does that mean, because my car runs, it's just doing so with some stuttering issues, especially with the AC going.
There are a bunch of other steps after, but i'm just curious what this means before I move forward
Okay, I'll try that later. Here:
Hey I don't mean to step on toes here :coy: but there is a VFAQ on checking codes for obd1
ECU Code Checking
You can do it with an ANALOG multimeter (the one with the needle, not digital)
Or the buzzer mentioned in the link
Or a red LED with a 560ohm resistor
My 2G has your similar symptoms with the coolant sensor unplugged, I don't know about 1G however
It means that the Haynes manual is wrong, no big surprise there.
The 1G doesn't run the fuel pump until your cranking the engine or the ECU sees pulses from the CAS. So people have noticed that their cars seem to prime the pump when you turn the ignition on but that's random likely due to the CAS glitching when power is applied and not by design.
Lol I was about to say. Who has a analog. But I have a real old one too LOL
ECU Code Checking
Thanks for the input but I think it's a few things that arnt working, a vac leak and some sensors. Together. Like 3 sensors and a big vac leak. Maybe pump going out.
Didnt really think about it till now but he's right. 1g don't start to pump till the car is getting started.
So I stuck my digital multimeter to the terminal to read the codes figuring it must work the same as an analog one just maybe more difficult to read, which it proved to be so, but for what it's worth, after a lot of time watching the results I came up with four different codes; 12, 13, 24, & 25, volume air flow sensor, intake air temp sensor, vehicle speed sensor, and barometric pressure sensor respectively. So I'll start testing this stuff...
Turns out my digital multimeter has this audible setting that just buzzes the codes out. Awesome! Works better than an analog dial I bet.
Edit: no code 24, just 12, 13, & 25
Okay, what I don't get though is this: Haynes says to check voltage at the wire harness, with it disconnected from the MAF with ignition on "on" (and other probe grounded) which there is none(at terminal two, top middle one) and that if there voltage is incorrect the MAF could be faulty, but how am I checking the MAF if it's sitting next to me and i'm not even touching it? And wouldn't that indicate a problem elsewhere in the circuit between the battery and the MAF connector?
F Haynes. I'm taking my research elsewhere.
1983gsp said:
Sounds lime a bad maf or poor connection to the maf.
That's what I thought but he said he unhooked it and didn't change anything
Lol I say a short in the maf wires. I really think it has a air shortage. Saying it smells like gas and all. That means you are getting good gas pressure. Just spark and air. U said u replaced spark plugs and wires right? Well air is last...
Make sure the MAF is plugged and and reset the ECU by pulling the room fuse or disconnecting the battery for second or two.
If the codes come back then you have a problem. Right now they could be from earlier testing if the ECU was on while the MAF was disconnected.
Good point. I may HAVE left the MAF unplugged. Will retest
By a second I believe he ment 20 mins or so. I think it takes 20-25 mins to reset it, right?
steve said:
No, the charge in the capacitors drains off pretty quickly. Why don't you try it and see.
Well I do all the time. Adding and stuff but I thought a full restart took longer
Then you should have noticed that your fuel trims were reset along with all other long term setting. Ask any 2G DSMLink V2 user.
  • For sale 4G63 3 inch fake cat converter.
    3 inch two bolt 19.5 long fake cat. Hollow inside. Flange bolts are 4.25 inch on center. Good...
  • Wanted Stock frame, Turbo manifold
    ISO: 1G DSM Tubular Exhaust Manifold – Stock Frame Turbo Location
    • Cj Anderson
  • For sale 1g Assortment of New, Used, and Unobtanium Parts
    All good stuff. Will sell individually or lot sale.
    • 8716valver
  • For sale 2g 95-98 Talon air bag.
    2g Talon airbag. Really good condition. Can ship ups ground. Message 702-741-6987
  • For sale Injen Intake System
    Good condition used Injen Intake System for Turbo DSMs
    • kyler021
