spyderdrifter
- 5,426
- 860
- Jul 11, 2009
Somewhere in,
Colorado
So I was running a compression test tonight and had a couple questions about reasons for certain procedures. I did do a search, but couldn't find ant conclusive answers since most of the posts on here relate to numbers and how to test it.
So anyway, first off is I know all the how-o's say run the test with a properly warmed engine. Why does it need to be warmed up? If it is done cold, are the numbers inaccurate in comparison to a warmed engine?
Secondly, is the throttle plate being open, absolutely required? While doing my test tonight, I did one cylinder with the throttle open, as well as closed, and got the exact same psi reading. I did this simply to see if there would be a difference in psi.
These questions are simply to seek out more in depth info to be posted for the community. And its all part of my own curiosity. Thanks in advance
