92 Tsi brake upgrade after abs delete
eclipsekid1013
162
May 9, 2010
hudson, New York
Hey guys I just finihed my abs delete. I'm replacing all my calipers and looking to upgrade to the 93 two. Piston front brakes. Since I deleted abs will there be any issues? Just need front calipers brackets rotors and pads?
It's works fine, just make sure you use the non-abs proportioning valve. While you're doing all that, I'd look into the Outlander brake upgrade. You may run into clearance issues on stock rims, but I'm not certain since I don't have stockers and didn't research that part.
Well I plan on keeping the car pretty stock. Did the jnz tuning abs delete. Snapped all the bleeders on stock calipers. So I'm going to order the 93 2 pistons and upgrade
If you are running the outlander front brakes on a 1 g wouldnt you need to use the 2g abs delete kit?
Very old thread but here is what I have done to 2 of my 1g cars. I put 2g calipers on them as a kit.
You can see it HERE, start at post #122 and HERE starting at post #92.
The 1g dual piston calipers are getting hard to find and this is a simple swap.
If you can find 1g calipers, then by all means, use them!
EDIT - Since it seemed that it was needed, I made a Tech Article for those that want to do the swap and all of that info can be had HERE for the conversion.
Marty
