1G 92 awd rear mount help
AWD-Tony
6,787
3,746
Sep 11, 2017
Cincinnati, Ohio
I need to order the correct mount. The one on right is what came out and the one on the left is what I ordered. When I bought the car guy gave me an extra mount with solid inserts but it’s also the same as the one on left. Don’t have too much history on the car so I don’t know if the motor, mount and bracket were changed at some point. It does seem to have been on there for a while.
Thanks
I made the same mistake ordering one from RockAuto. They have the incorrect part listed, at least they did when I ordered mine. The difference is the one that they have listed is for an AWD, but the mount is for a FWD. They do not make the AWD one anymore. No one sells it. I had to buy a used one from Miller import parts. I have an extra one, but it has a Poly mount and will make your car vibrate quite a bit.
Thanks Jakk! They ordered the other listing they had which was for auto. Keeping my fingers crossed that’s the correct one. You have the mount for 1g? If I can’t get the correct one will you sell me yours? I have solid polly insert that I’m trying to install. I know the vibration will be felt inside. Had a 2g long time ago and it didn’t bother me. Vibration is worse in the beginning but does subside
