AWD-Tony
- 6,787
- 3,748
- Sep 11, 2017
Cincinnati,
Ohio
Are rear engine mounts the same? Do you have one for 1gb?
Thanks
Thanks
Seriously doubt the parts store gave you awd units. I'd use that scratched up moint. Doesn't look bad.You must be logged in to view this image or video.I’d use this one but I had to cut off the bolt which was seized
Couldn’t get the shorter mount. I used applied quik steel and it’s been fine. The taller mount bolt holes won’t line up.Hey @TK's9d2TSi , just curious what you ended up doing. My car was an auto and Im working on swapping it to a manual. It had the shorter mount originally. I ordered the AWD manual mount to do the swap and I also received the taller mount. My issue is that the taller mount wont bolt to the frame.
Did you ever try installing the taller mount? If so, did the bolt holes line up?
Do you have a manual trans and did you just go back to the shorter mount?
Works for me. I ordered what rock auto says is the auto mount, but I'll probably just end up doing that.Couldn’t get the shorter mount. I used applied quik steel and it’s been fine. The taller mount bolt holes won’t line up.
