90 gs speedo gear adjustment questions
RCAmechanic
Sep 28, 2014
orem, Utah
So I just bought a 90 eclipse gs and it has a smaller tire than what it had from factory on it. So of course the speedometer is off, are there any sort of speedo gears I can get for this car to make it accurate or is there any way to adjust the speedo to be accurate.
Well the speedo reads at 75 when I'm going 65, the cable does make a howling noise at higher speed so I might replace it, where would I get the smaller gear?
If there is a different gear than you would have to switch the gear inside the transmission also. There isn't much of a solution here other than running the correct diameter tires.
Ya I haven't been able to find any others online so they probably don't, thanks for the info, what would the factory diameter be?
Hmmm if so then my speedo may have a different issue cuz I'm running 205/50r16 tires and it seems to make like a 10 mph difference at higher speeds
Just so you know, there aren't different size speedo drive/driven gears to compensate for different tire sizes. You'd need to make custom gears, or get a custom speedometer.
185/70/r14 would be the stock tire size for a 1g base model, not sure if thats what a gs came with. However since they use the same transmission i would assume it would probably be the same tire for a GS as well. If the driver side door sticker is still intact it will tell you tire size and recommended pressure.
If the speedo is off by that much i would look at the gauge as the suspect. More than likely someone pulled the needle off at one point and didn't put it back on perfect.
Ok good to know about the speedo gears, also I'm running the factory 16 tires but it does seem to be too much of a speed difference cuz at 75 on the speedo its 62 based on the digital sign I checked it with[DOUBLEPOST=1411960167][/DOUBLEPOST]Makes sense the needle does like to vibrate occasionally so that may well be it.
(1) based on the digital sign I checked it with
(2) Makes sense the needle does like to vibrate occasionally so that may well be it.
(1) IDK why they even put those things on the road. They are TERRIBLY innacurate, ignore it. Download a GPS speedo app on your phone and maintain a constant speed and compare. You shouldn't be too far off.
(2) AFAIK, 1g cars just do that. Mine does. I dont really care. FYI I am on Enkei 17" with a reasonable sidewall, and I am ball park close enough. My car over reads just by a hair, so I like it. I am actually slower that I think helps save me on photo tickets etc...
My friend had a honda with a Euro gauge (only KM/h) He decided to write a speed reference conversion chart and stuck it next to the speedo LOL, you may consider the same. Or buy a husge river speedo from autozone.
The difference in speed seemed too extreme for the difference in tire size. But I think GSLENK is right about the speed sign not being accurate so it's probably not as far off as I thought
