- Thread starter
- #26
hollandeclipse
- 39
- 0
- Nov 20, 2003
Europe
With the ostrich you mean the ECU+ tuningkit sold by Mach V right?
Today I checked base timing and it was about 9* btdc. So I decided to set base timing now at 3* btdc but my problem is still there.
I have to set my AFC to the positive side still.
At low I have to set my AFC at 0. At high I have to set it to +6. This should be pig rich but my FTRM is 115 % and my FTRH is 135!!
Any other ideas what I can check now?
Yesterday I did a WOT 3rd pull outside temp was 39F. Boost set to 18 psi.
RPM O2 TIMA knock IDC TPS
3843 0,91V 19 6 46% 56,2
4593 0,91V 16 5 71% 99,6
5312 0,89V 19 3 83,5% 99,6
5500 0,89V 20 4 86,7% 99,6
6000 0,89V 24 3 89% 99,6
6375 0,89V 23 1 92,1% 99,6
Any advise? seems that my 650cc's are having trouble keeping up with the airflow. Or is anything else wrong with fuelsupply. This also explains why I can't richen it up further cause I will pass the max IDC.
If he had a boost leak the trims would look the opposite. Low being the highest and high being the lowest.My fueltrims are:
Low 101%
Mid 111 % (very long time to change, difficult ot get any lower)
Hi 135 % (not changing at all not even after 14 days)
Can you pull your spark plugs and tell us their color. Posting a pic would be best.I did do the smoke test and it was negative we could not see any smoke from the exhaust. To be honest I had expected it also but not even a small black one.
Is it possible to check the fuel pressure if someone else sits on the one rearsit and the other rearsit is fold down to reach the fuelpump or is this al silly idea.
Because my cranckpully was starting to separate the readings with the timinglamp wasn't accurate. Last sunday I retarded the cas without the timing lamp just up untill the point that the enige was still running smooth at idle, I went out with the wideband and logger and finally I was able to get rid of the knock. i am seeing 19-20 degrees timing at WOT untill 6000 rpm. Between 6-7krpm it rises to 25 but with some enrichment of the mixture at these rpm's and the premium pumpgas overhere (98ron) i am finally able to control knock.
So you are out doing pulls and turning the motor at 7000 rpm's, with a HB that you know is starting to separate?
Good luck with that.
