gringo72884's Eclipse GST
Mitsubishi Eclipse GST
3" custom Stainless Steel Turbo back exhaust, dejon tool 4 inch intake, Hallman Pro ES mbc, Magnecore 10mm wires, Moshimoto Aluminum Radiator, SPAL slimline fans, NGK BRP7ES's, ETS Ultra Race FMIC, PTE 5857 billet wheel turbo w internal HD WG, Evo III Gt ported exhaust manifold, Punishment Racing SS recirculated O2 housing, Fuel Lab mini afpr, Walbro 255 hp fuel pump, FIC 950cc injectors, HKS SSQV BOV
Mods-Engine
6 Bolt Swap with 2G Head, Manley Platinum Series Pistons, Ma Performance Ultimate duty billet Rods, Ma Performance Ultimate duty H11/L19 headstuds, ARP mainstuds, Eagle Billet crankshaft, Kiggly racing Main Girdle, Kiggly Racing beehive valve springs and titanium retainers, mitsubishi 4 layer Metal head gasket, FP2 cams, ferrea Steel valve locks, Ferrea viton rubber high temp valve stem seals, Ferrea bronze and magnese Valve guides, Ferrea Stainless steel valves, fully balanced rotating assembly,
Mods-EMS & Logging
DSMLINK V3, Speed Density, AEM wideband, Autometer boost gauge, Prosport oil pressure gauge
Mods-Drivetrain
Slowboy LSD Converter, ACT 2900 pressure plate with 6 puck disc, Fidanza Aluminum lightweight Flywheel, aluminum Shifter bushings and shifter plate bushings, custom short shifter
Tokico HP suspension Kit, RM Racing front and rear sway bars, Rear strut bar, 17" OEM 2G GSX rims with Continental DWS Extreme Contact tires, Avid Racing 75A motor mounts
Parts Wishlist
Magnus or Venom sheet metal intake manifold, Magnus fuel rail, Quaife LSD, water/alcohol injection
1/8 Mile E/T
0.000
1/8 Mile MPH
0.000
359.4 lb/ft
Dyno Type
DynoJet
Dyno Sheet Photo Link
Dyno Shop Name
AMS
Dyno Session Details
Nitrous : No Nitrous
Fuel Used : Pump gas
Turbo : PTE 5857
Boost : 28
  • Like
Reactions: paw7889
gringo72884
More in 2G DSM
Share this Vehicle
