chrisman287
5+ Year Contributor
- 1,157
- 1,110
- Jul 19, 2021
New York
I’ve been having a bit of an issue with the car running and noticed my timing is slightly off. I took everything apart to redo it but noticed the side motor mount bracket won’t allow me to insert the long tool to compress the auto tensioner. I ended up loosening the tensioner pulley which allowed me to remove the belt.
Should I remove the bracket to be able to insert the tool to compress the auto tensioner and install the belt like normal or can I just slip the belt back on and tension/tighten the tensioner pulley?
