2G 6 bolt swap idle issue
Dsj3818
Sep 30, 2020
Adelanto, California
So did a 6 bolt swap on my 97 eclipse gst did the cas and everything is wired correctly I’m running into the issue of it running extremely rich I’ve replaced everything from maf, map, idle air control valve, tps, did a boost leak test, new 02 sensor vacuum lines are all deleted including boost restrictor and after replacing all of these parts the car still runs exactly the same even though it’s amazing when i have my foot in it
the car won’t run unless timing is fully advanced and the cas is also not 180 out my coolant temp sensor is good everything seems to check out including compression test but I’m still getting an idle as if it’s misfiring and it also won’t stay idling unless I keep my foot on the pedal
