BLACK'98DSM
Moderator
- 5,515
- 3,038
- Feb 9, 2019
Alabama
I've rebuilt my 4g37 and installed a new timing kit, and now I'm trying to determine if I am using the correct timing mark. I see a small notch behind the washer on the crank sprocket and was using that to time the engine. Reading through old threads, it seems as if no one could provide a straight answer about said timing mark. The FSM and Chilton manual both say to just "align the timing marks" but do not provide any detailed images of it. See my picture below. What mainly has me confused is the faded mark that someone has previously made. Everything was covered in rust and oil prior to removal and I did not check how it was oriented before teardown. Other pictures included to verify proper timing, does this all appear correct?
I felt very confident in my work but the car is having problems that it should not be having after properly being rebuilt so I needed to double check. Thanks,
