1G 4G37 Rebuild issue
Magiceton
50
5
Nov 20, 2025
Illinois
Currently I have the 4g37 pulled out of my Talon to reseal it and replace any hard parts that are worn, and upon removing the outer timing covers (both of which snapped 🫩) and then cleaning behind the belts, I discover what appears to be JB Weld between the water pump and engine block and rear timing cover. Is this cause for concern or just a broken bolt someone covered up in the past?
Pictures please.
Pictures please.
Pictures as requested. I think it might just be an RV because it's malleable
GOOD NEWS, JUST SILICONE 😅
Agree with Paul. Replace as many seals as you're able to, since you're already in there. And get those sprockets & surrounding areas as clean as you can to prevent damage to a new belt.
Please get some degreaser, some brushes and spend an hour. Are you replacing all seals?
These photos are after 3 days of cleaning
