2G 46g3t Manual crank turning
drthorp
5+ Year Contributor
75
35
Oct 22, 2019
Trussville, Alabama
Been doing a some work on my '96 gsx (timing, water pump, crank/cam front seals, etc.) and while turning my crank to align the timing marks and it wasn't really difficult to turn by any means but the was more resistance at some times than others. I have all the spark plugs pulled but I have the oil pump and timing belt installed. The car was running strong before I ever started taking it apart so if there is an issue, I might could catch it early, or is this sort of resistance normal? Note: I am lubricating the cams the best I can before turning the engine at all.
As the rotation comes to the point you are compressing valve springs, it will get more resistance while turning the crank over. That part is normal.
I figured that was part of it since the engine ran like a top literally like two weeks ago. Also When I do rotate the engine and just as I overcome this resistance (I guess where the valve springs are decompressing or whatever) I hear a small "whooo" sound like that of a empty bottle when you blow on it. I know in my g35 this noise is kind of normal based on acoustics with good compression, but is this a sign of worn rings or bent valves? Its a subtle sound and seems to be air driven, just curious to know if you've ever heard/diagnosed this sound before.
Yep, absolutely normal. Usually when assembling you first check if the crank rotates absolutely freely while just sitting in the girdle with a bit of oil and the bearings installed, no rods or anything attached. Then you try rotating it again once the rods/pistons are all in place, again to check for any problems. And the last step is to check how it all rotates once the head is on with valves/springs etc. As Marty said, there should be more resistance as some of the valve springs start to get compressed.
During all those 3 checks it's easy to determine if there's indeed a problem with the rotation of parts and any binding.
Even with the spark plugs out you will still have crankcase compression and that is what you are likely hearing, the air moving between the bottom end and the top end.
Ok that makes sense I just wanted to make sure my assumptions are correct. Time to pull some cams.... thanks guys!
Quick question...the oil pump sprocket has a small circle on it that looks like a timing mark of some kind, but in the manual it looks like there is supposed to be the actual timing mark on the other side of the sprocket (180 degrees off of the circle mark). Just wondering If maybe there used to be a mark that wore away or if the actual indented circle(dot) marking is supposed to be lined up with the timing mark... I can get pictures if im being unclear.
Get us a picture so we are sure. My oil pump sprocket has a small triangle on it only, for the timing mark. I have all 1g 6 bolts though.
Here’s what I’m working with. Just a little confused as to why I’m seeing different things. This is the 96 service manual and everything...
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 2g 2G 7 Bolt Cylinder Head
    2G 7 Bolt Cylinder Head $250 + shipping & paypal fees* deck surface measured measured at 5.20...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
