3D Printed Car Parts
More and more people are toying with 3D printing for car parts. If you've printed any parts for your car, please post some articles in this section describing how you did it. Whether if was for your DSM or not. With more and more OEM DSM parts becoming obsolete (no longer produced) 3D printing will become a popular option in this community.
Here are some resources I found to give people more info on getting started with 3D printing car parts.
Post your own Articles on this subject!
Wow what an amazing thread so many skilled designers, imagine if more of these STLs were actually shared amongst community members. The STL file only thread is much smaller than this one.
It was my idea to create a thread like that, in order to get a collection for the community, because some parts are not available anymore. I hope the 3D printing files thread will get bigger and bigger. 🤝
What machines is every one using and fillements? Last winter I got the Qudi plus 4 and playing with different fillements, and learing fusion 360. Currently upgrading the SSR, rear fan and heated blower fan case.
I use 2 Prusa MK4S units and a MK3S+
My go to filament is Atomic or 3DFuel
Oh how i wish someone would design a 3d model for the 2g spyder driver side door panel bezel where power windows/lock buttons are located. Impossible to find one without broken supports.
I actually have a 3d scan of a good bezel for this, I've just never gotten around to processing it into a model
That's where I'm stuck, what to do with scanned data. Lol I have scans but no real idea what to do with them. I presume somehow import them into f360
I can probably help you with that. Depending on what your scan output is, if it's a point-cloud first thing generally is refine the cloud into a mesh, and then "thicken" that mesh into a solid. I haven't used F360, but I have used Solidworks and Solid edge.
This stuff is brutal to learn if you haven't done it before but just keep pushing. Here 8s a little part sample that I'm doing. Scan the part , moved it to fusion 360 and moving it.
In fusion you build off of a build plane or
planes . The problem with that , is that the radio area has a lot curves and angles to match the center console. So what I did was use the center line and build up and branch out and connect the dots.
For those printing precise parts, I have found the tool in the below link to be very useful to calibrate your filament to get as close to the dimensions you request. It requires some measuring and the use of an excel calculator (instructions and tools are included) and worth every bit of the 8 bucks they are currently asking. I am in no way affiliated with these folks, just thought it may help others to get their calibrations dialed in if needed.
Califlower Purchase link
Now the thing is that I've noticed with 3d prints is their ability to be hydroscopic, they draw in moisture from the the air. So with that being said if you immediately apply a chemical, say a resin or a glue it will help with applying like fabric, to bond to a 3d printed part. So if your doing this do it after the part come out of print or dry the part in your printer or what ever later.
Latest but not complete double drink holder with optional holes for 16mm round switches.
This looks great! What material and printer (nvm: I didn't read far enough back, saw you're on the QIDI Plus4!) are you using?
Also, killer work on the center gauge setup as well. The pleather wrap looks killer!
  • For sale 2g 2g GST auto trans case
    2g auto trans case. With bearing plate and end case covers. Good condition. Trans was like...
  • Wanted 2g 2g radiator support
    Im looking for a radiator support if anyone has one
    • Fundsm
  • For sale 4G63 3 inch Magnaflow SS high flow cat. CA approved.
  • For sale 4G63 Race parts.
    Brand new seal in box Kigglys HLA 175$Kigglys 12 tooth billet crankshaft triggel setup 250$...
    • GST2012GSX
