m_0ney_pit
- 819
- 87
- Jan 12, 2007
Easton,
Pennsylvania
So I had a 3 angle valve job done to my 1g head to freshen things up. I had lapped the original factory 3 angle cut with new stainless steel valves (engnblr) and did not like the results because although there was a solid line around the entire valve and seat it varied for each valve and seat. I'm geussing the seats were pretty rounded.
After the fresh 3 angle job I relapped the valves and have a nice thick solid line all the way around that is exactly the same for each valve/seat combo.
My question is, the angle furthest on the outside of the seat has a dark gray line while the 2nd and 3rd look shiney and new like they were cut. Everything seals up perfect and holds pressure without leaking at room temperature.
So got some questions:
1. So what will happen when the head is at operating temperature and whats the purpose of the 3 angles in the first place? Do the 2nd and 3rd angle get used as the head heats up?
2. I was told that the abrasive from the lapping job can shorten the seat and valve life, is that true?
