m_0ney_pit
- 819
- 87
- Jan 12, 2007
Easton,
Pennsylvania
Quick question is the 2g stock fuel pump a switched ground wire black with white strip?
Reason I’m asking is a while back like more than 10 years I did the fuel pump rewire and used the chassis ground for the pump and relay and it worked fine.
Rewired the pump with fresh wire and relay and thought about using the stock fuel pump ground wire to ground the relay like I saw some others do. No I’m not trying to ground the pump ground to this wire just the relay!
Went to test the continuity from the ground wire black with white strip to the chassis and it is open so not connected. Is it cut somewhere else or is the black with white strip a switched ground?
