ncarson91
5+ Year Contributor
- 138
- 19
- Jan 2, 2021
north olmsted,
Ohio
So I replaced both sensors for engine coolant temp. I know they are picky and specific to which sensor has to be installed, make or model or trim ect can throw it all out of wack. Need specific sensor for mine which is a 98 GST. ANYWHO! I 300% made sure I have the correct sensor but my engine coolant temp is reading -74 degrees.
Now how is that even remotley possible? I'm at a hard confusion now, old sensor says same.
Yes I have two, thought 1 was faulty when clearly wasn't. It's reading fine through multimeter. Car starts, runs, I hit gas it commits suicide. Stalls out. Mind you I wired all my excess gauges to a switch to its own mounted terminal. Thus allowing me to switch them on and off besides logged wideband. Has its own seperate ground location so its not interfering with any sensors.
ECU is in mint shape had ECMlink check it out with the addressed 55$ inspection cost. Plz halp.
