Coolant Temperature Sensor stuck
boostedgst523
57
Oct 29, 2007
Houston, Texas
Like the title states, my coolant temperature sensor is stuck. I've tried a wrench, penetrating oil, and vice grips and it still won't come out. I've been battling with this sensor so much that I stripped it a little. Is there any other way possible to remove the coolant temperature sensor? Any advice and tips are appreciated. Please help :pray:
Have you tried a ratchet with a socket on it? That will give you alot more bite/torque than with a wrench or vice grips. Maybe putting a little heat on it with a propane or mapp gas torch would help break it loose.
Try heat depending on where the sensor is, be careful about using too much heat. after you heat it take a non scented candle and see if the wax will wick into the threads.. Dont over do it , just a little wax.
Unfortunately, it's too stripped to get a ratchet with a socket on it. I didn't have deep sockets that's why I tried the other ways.
I'll try to heat it as you both said and I'll get back to you guys :thumb:
Thanks for the quick replies guys.
I tried everything advised and I ended up stripping the $hit out of it LOL. I have no idea as to how I'm gonna remove the sensor. If worst comes to worst, I think I'll just have to buy the lower part of the thermostat housing (if that's even possible). Other than that, I'm clueless.
Best thing to do with a stuck bolt, sensor, etc... Heat the area AROUND the bolt (or whatever), until it gets good and hot. Not red hot if you are using oxy-acetylene, just too hot to touch, and try to keep the heat away from the bolt. Yes, some heat will radiate to the bolt and heat it up too, but not as much. This will make the hole expand. Next, spray the bolt/sensor with penetrating lube, and let it sit for a while. Between the expansion of the hole, and the adding of the penetrating lube, it will break loose. You may have to do it a couple times, but it will work.
Would this work on over tightened bolts?
  • For sale 1g 1G AWD Fuel Filler Neck
    1G AWD Fuel Filler Neck $75 + shipping & paypal fees* I would replace the rubber elbowYou...
  • For sale 1g 1G 4 Bolt LSD Rear Axle Set
    1G 4 Bolt LSD Axle Set $120 + shipping & paypal feesYou must be registered to see...
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
  • For sale 4G63 6 Bolt ARP Head Studs
    ARP 6 Bolt ARP Head Studs $65 + shipping & paypal fees* these have been torqued onceYou must...
