2G Coolant temperature sensor pigtail
Sorry to revive again, need the lower sensor (to the gauge) part number for the connector only. Its the littler stupid one, # 37 in Brians outline. Apparently the pins in my connector are bad, so does anyone know the mitsu part # for the whole pigtail? Thanks guys!
Correction: its number 38 and i need the part number for the pigtail harness. Mine the pins backed out and it is not repairable.
Hmmm you need the lower pigtail temp sensor? the one with 2 wires? that's the temp for ecu not the gauge or maybe I'm not understanding what your question is!
Looks close :hmm:
From the link: http://www.dsmtuners.com/forums/art...047-2g-engine-bay-electrical-connections.html. Number #37..
From the link talon2gbuyer provided: More Information for STANDARD MOTOR PRODUCTS S820
Interested because i broke my connector too. Exploring other options also.
If this connector works, it would be great. Most of our stock CTS connectors are most likely junk and about to break.
Im using a small set of those gold plated female connectors for now. For $30 im gonna wait till payday before trying it. Ill keep you guys posted, hopefully we just found the solution to the burning question of where to find a new one :)
Nothing is wrong with it per say.. but it needs to be pinned. And unless you order the kit and know what you're doing its best to just buy the pig tail. You can screw up more stuff and cause a bigger headache if you dont know what your doing with it.
