biglady112
- 1,975
- 559
- May 20, 2004
Commerce City,
Colorado
Well I can personally say that I have seen first hand the difference in the way a stroker and 2.0L spool a specific turbo. I got a chance to tune Ludachris'(site owner) eclipse yesterday.
His car is powered by dsmlink. His basic mods are 2.3L Wiesco/Eagle, DNP tubular manifold, SCM6152, and all the necessary things for the car to run well. Well my friend daughter's car(590whp talon) has the exact same setup(only 950cc's instead of 850's and a 2.0L Wiesco/Eagle) and is(was) also powered by dsmlink. She now has AEM.
Well, the only significant difference in their cars is one is a 2.0L and one is a 2.3L. Well after getting Chris' car running well and after reviewing the logs and comparing notes, Chris' car and Tara's car spool and act just the same off and on boost. The both have the same turbo, intake/exhuast manifold's, cams, and fuel setup.
Both vehicles made 20psi by 4200-4300rpm. The off boost spool and power and drivability were identical. I went home and looked at her logs and there was absolutely no difference in the way the cars flowed, spooled, 60-90 times, or anything.
So in this particular test, at the same altitude(6000+ft) a 2.0L and 2.3L spooled the same. The other good news that I have is that Chris's car is now pumping out 51lbs/min on pump gas @20psi. This is a very safe tune for the conditions we had to tune. With some dyno time I am sure 2-3psi more and 3-5lbs/min can be found. Especially is we remove the air filter.
These turbos, the SCM61's are totally streetable. They spool early and make good power by just giving a little throttle. 4200rpm spool is not bad for a turbo with this kind of potential.
Steven
Steven
, we can take it for a drive and get some of that A/F ratio worked out. You have so much more potential sitting there. It is fast now, but imagine another 50 horsepower, at least.
