- Thread starter
- #76
GSLENK
- 1,416
- 55
- May 25, 2011
DC,
Maryland
Ok i got it. you have to use a 9005 bulb there. That's what the oem socket will take. I was confused when you said h1, I assumed somehow you fit the bowl in there.
Idk about light output, but it will at least "look" lit up when turned on. Not much light comes "directly" from a bulb most of it is reflected out. If you were willing to show internals and such, I would have just went the matchbox setup in there raw.
That way you could still run a mostly focused HID bulb in there. I actually tested it out, and the matchbox adds very little light to the mini h1's. It just gave me more foreground light, and put a few flaws on an otherwise perfect cutoff from the mini h1.
BTW, if anyone is looking for clear headlights, I came across this yesterday -
) Expect to pay between 50 cents and 15 cents depending on volume ordered. These are official leds, also CREE makes good leds but phillips are easiest to obtain.
