Resolved 1G I forgot what this bracket is for (throttle body stay)
wingspan99
Mar 28, 2009
Colorado Spring, Colorado
It's been a while since I tore my 90 TSI apart and now I can't remember where this goes. I used a cable tie to keep the nut and washer with it but I just don't remember. Is it brakes, suspension, driveline, or engine? Also, I pinched through the rubber boots on my ball joints, I should probably buy some new ones? Thanks. -Tom
Solution
Specifically it goes on the throttle body bolts and a CAS stud ;)
In CAPS it's call a throttle body stay.
And yes, I would send a few bucks your way for that.
Agree. I just took mine off the other day to remove my throttle body to replace the leaking shaft seals. The single hole end bolts to the left mounting stud for the CAS and the double hole end bolts to the right side bolts of the throttle body.
I had my TB off the other day to replace my tps and that bolts to the front of the TB and to the back stud of the CAS
Is there something I don't know about this useless bracket that somehow makes it useful?
Too bad I just threw the one away I got on a parts car.
Ok that's why it was so hard to hoist the engine the second time around! Thanks to everyone who replied to my Q. I'm going to bolt it on the engine and hope that I never have to use it although I have a lead foot so the chances are good... Wow this is a busy site, that's great.
-Tom
I don't think so. I just have no nice way to pull the engine so I'm going to see if that bracket will help. The other 2 engines I've helped drop in recently we just wrapped chains around them, but we didn't like that, especially around the valve cover.
anyone know what this bracket goes to? im working on a 93 plymouth laser with 4g63. i put a head on it but before i got it was already taken apart
thanks
Hey guys..
So i just put my throttle body and elbow back on my intake manifold.
I used the gaskets that came with my gasket kit, but now the two studs that hold the
throttle body and elbow on are too long.. the threads arent long enough to allow the nuts and lock washers to contact with the elbow and hold the assembly to the intake manifold.
Did i miss something that goes on with the TB and elbow? WTF
i know the stock gaskets are thicker but i dont think that make too much of a difference..
Hey guys..
There is a cast iron bracket that goes from the TB to the cas. I usually just toss it in the trash, Pull the studs out of the manifold and get appropriate length bolts :thumb:
Hope this fixes it
dee
is this necessary for other than pulling the motor? the manifold has a bracket underneath it, is this enough bracing?
  • For sale 2g Early 95 2GA DSM Hardtop for sale (5-speed)
    2G DSM for sale
    • codexes21
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
