1G Throttle body plate
Adrian97
5+ Year Contributor
100
Mar 3, 2018
Göteborg, Europe
Hello everybody!
I unscrew the link on the cruise control and as I screw it, I see that the throttle plate moves. In which position should the plate be? completely closed or is it supposed to be open little bit ?
Okay. Do u know where can i find these spec ?
Can I just set it so that the cables are tense and the throttle plate is closed ?
I have only pdf service manual which is on the site so ok,I just srew until TB plate will be closed and then screw litlle bit should be ok
