1G How to: 1g DSM CTS-V big brake upgrade
06 Caddy CTS-V 4 piston front calipers to 1g DSM conversion outline.
First and foremost you are going to need to test fit the calipers to your wheels. There is no way to know for sure about barrel to caliper clearance other than trying. This will require purchasing at least one caliper bolting it up and measuring the difference. Brembo recommends at least 3mm, mine was about 1.5mm-2mm which I can live with. You will also need a lot of 12mm washers to help simulate spacers etc. NOT ALL 17” wheel will fit, for guaranteed fitment buy an 18” wheel if you don’t want to do this measuring part.
Now in reverse if you have the brakes and would want to change wheels you would want to test fit that wheel over the caliper before buying four wheels and tires just to find out they don’t clear.
Parts needed
  • 04 -07 Genuine GM CTS-V 4-pot front brake caliper (LEFT) GM# 89047727 ACD# 172-2287 new from Rockauto -150$
  • 04 -07 Genuine GM CTS-V 4-pot front brake caliper (RIGHT) GM# 89047726 ACD# 172-2288 new from Rockauto -150$
  • Brake Caliper hardware kit AC Delco P# 18K1971X new from Rockauto 25$
  • HAWK pads for 04-07 CTS-V calipers P# HB453S585- HT10 Compound -Summit $280
  • 03-04 Cobra 13" Power stop rotors (left and right) P# PWR-AR-8144XPR -Summit 260$
  • Caliper mounting bolts (x4) ARP 12X1.75mm hex head P# 665-1003 - Summit 25$
  • Banjo bolts for CTS-V calipers (x2) Dorman P# RNB-14100 -Summit 15$
  • Motul 600 brake fluid (x2) P# AAF-ALL78117 -Summit 40$
  • OEM hard line adapter 10X1.00 IF to – 3an (x2) PN# 989537ERL -Summit 16$
  • SS flexible brake hose 9” long (x2) PN# ALL46300-9 -Summit 24$
  • 3/8” banjo fitting 90* to -3an (x2) P# SS9976093ERL – Summit 36$
  • 10MM copper crush washers (x4) P# 177101ERL – Summit 10$
  • ARP Wheel Studs (4 packs) P# 100-7716 – Summit 175$
  • Rotor hub rings for 03-04 cobra rotors 67mm ID RTM P# 1K-RTM-8112 $40
  • Caliper backing plates 1mm thick (two packs 8 total) Giro Disc P# TS-1001-4 STM 190$
  • Machine work removing 6mm off the ears of the calipers 100$
  • Total was ~1,550$
  • You may also need additional wheel spacers to clear the calipers, that would be approx another 50$ on ebay
See video for complete details and more in depth discussion.
Great video, Thanks for sharing. How does it compare to the mustang cobra calipers? Also can you please elaborate on your rear brake upgrade?
I give my review of the calipers at the end of the video.
The rear brakes is a full on custom thing, there is nothing to discuss really. It basically proprietary, can it be done again? Yes, but I am not going into how and what was needed.
Probably a dumb question but is there any chance a 16" wheel will clear this brake upgrade?
You need to figure out the barrel size of your rims. So the Evo 8 Enki wheel specs/offset are the closest you can use with the CTS-V fronts. That being said, compare your rim and barrel specs/offset with the Evo 8 Enki's and if they are the same or bigger, they will fit
How does your hand brake work is it hydraulic ?
