all black 4G63
5+ Year Contributor
- 270
- 50
- Aug 5, 2019
Chicago,
Illinois
Hello,
I recently rebuilt my transfer case from parts of spare t-cases layin around. I replaced the drive gear preload taper roller bearing ( this is the bearing on the input spline side of the case). This is the only bearing I replaced and was sourced from Autozone since I could not find the OEM one. I then replaced all the seals and re-assembled per the service manual specs.
My question is; the input shaft drive gear turning torque per the service manual is 1.23 - 1.81 ft.lbs. (input drive gear side) this seems really tight to me? I am actually right at 1.23-1.25 ft.lbs. which apparently is within spec. However, I feel as this will smoke my viscous coupling for some reason and put strain on my trans? I can't turn the shaft my self by hand it is that tight!
My back lash is within spec right .0031" and I honestly could not get a god contact pattern reading, but it seemed ok.
how stiff is this case supposed to be after setting the tolerances. Did I do something wrong? is this the result of replacing only one bearing and reusing the other 30 year old ones? is it super tight due to not wearing in with the proper oil? am I just paranoid?
sorry for all the questions, like everyone one else with these cars I have WAY too much time and money into it to allow my trans to smoke because of these t-cases..
Thank you for any input!
Anthony
sorry for all the questions, like everyone one else with these cars I have WAY too much time and money into it to allow my trans to smoke because of these t-cases..Thank you for any input!
Anthony
