1990 1ga pop up headlight bezel
Fakesmi1e
Apr 4, 2021
baton rouge, Louisiana
Hello i am new here and i just bought a 1ga , sorry if this post has already been made but i have looked as much as i could on this forum and i have looked on parts catalogs and i havent found a part number or anything . The car i have bought had some LED light bars and i am planning to go back to using headlight bulbs to pass inspection , i have bought the headlight bulbs and the new connectors to make the headlight bulbs work because the previous owner hardwired the old light bars so i had no connectors for the bulbs , the problem i have is the headlight bulbs wont stay in the assy because the holder bracket is missing if anyone could help me find a part number for the bracket or if they have spares i can purchase that would be greatly appreciated
Also if someone could give the connector endview of the headlight bulb connectors so i can know what wires to connect from the harness side of the headlight bulb connector that would be greatly appreciated as well . Thank you and Cheers
Here's the Mitsubishi part number. You may have to go used, part-out, or junkyard. You can contact Miller Imports.
nope i found 2 new online from mitsubishi thank you very much for your response hopefully i can look around for the pin out on the headlight bulb connector
