jpmxrider489
- 2,415
- 152
- Apr 4, 2010
pittsburgh,
Pennsylvania
This setup was installed on a 1g which I guess has more room from the motor to the rad. Anyhow, Does anyone see a easy way around this issue? I got two push fit fittings from fragola which are shorter than normal fittings. I even tried a long route but its still two tight of a bend. Does anyone know of a way around this that doesn't involve having it re-welded? Maybe some super compact fittings? I tried a push fit straight fragola fitting with a normal 45 fitting. With this combo, the hose isnt exposed at all. That doesn't allow any movement. I think with some tighter compact fittings it will work.
. I had to cut it off make the rad end shorter and take it straight back to the welder.
