New cooling setup, spal fans
Some pictures I didn't add and a quick update on the final setup. I did not use the Mitsumoto thermostat, I went with a stock thermostat. I removed the heat wrap from the manifold because it discolored. Last thing, I went to lowes and bought some aluminum "U" channel and had it welded on my FMIC so the ductwork just slid in the channel and wasn't taped on.
My temp never reaches 200*, even at the track on a blistering hot day as I hot lap with the A/C on in the staging lanes. So all in all it was well worth it.
What kind of material did you use to make that cowl and where can I get that? Looks awesome! Did you cover the underside also?
I have spal fans as well along with a radiator shroud.
Wow very nice thats what I want to to. What spal fans are you running?
